electric fan questions.
#21
RE: electric fan questions.
I have 4500kms on my rebuilt 308 with afr 185 heads rpm2 intake, the only coolant I use is the prestone premixed coolant.
and a bottle of redline watter wetter.
what thermostat are you using?
the hottest it gets here is 30-35 degrees celcius
#22
i think the thermostat is 160... not for sure though... but it dont matter cuz i run 190-200F... an the rest of the stuff... celcius... you'll have to do the calculations.... [sm=alcoholic.gif]
#24
I would go with the fan... as far as the rad cap, if it can handle the presure i would go for it, but only you know your car... my rad can handle the presure and it only helps prevent boil over....
#26
ORIGINAL: silver91gt
will having a higher pressure cap decrease the temperature too?
I dont know what griffin rads are able to handle.
treesloth
09-28-2015 07:03 AM
09-25-2015 09:06 AM
