take a coat hanger and leave the hook on it and hook it on the inside handle and pull on it and it should open. slide the coat hanger inbetween the weather striping and the door.
a coat hanger, leave the hook and slide it in right above the door handle. fish around until you see the lock pin moving and focus on that area. once you have the bar pull up.
also I've slid a thin screw driver in the hole where the hindges are in the door handle and caught the lock rod there.
dude foxes are the easiest to pop!....slide it just behind the key hole after you get the hanger between the window and weather stripping...slide down and just go up and down a bunch of times and don't be afraid...you'll hit the bar hard enough it will pop the lock.
