Locked Out! Help!
#21
RE: Locked Out! Help!
Take a flat head screw driver about 8 inches long lift up your door handle and find the hole closest to the key hole stick the screw driver into it and feel for the door lock bar. Once you feel it push on it with the screw driver side ways and you will be able to unlock your door. It may take you a few tries but you will get the door open for sure TRUST ME on this. It can be done on ANY 87-93 mustang.
#22
DUDE! i had the same problem! I tried everything and the absolute easiest thing is: take two screwdrivers(an extra hand will help alot) and pry the top of the door open just enough to slide a hanger with a hook in and grab the door handle on the inside and just pull hard. It took me two minutes!
#23
Got it! Man it was scary how fast I got it open with the right tool.
Fawk! That was too easy...next time I hav the panels off I'm gonna do something about that. I'll make sure I have spares before I do.
I've only had the car a few weeks and just haven't had time for keys.
Thanks for all the help.
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
