Beautiful plugs, no smoke, no leaks...
...and is still the fastest Mustang I've driven to date, yet it still takes its usual quart of oil per 1k. What's up with that? Would you be worried? I pulled my plugs today, just for jollies. They were all clean as can be. They were a uniform grey color, with no deposits, and all looked identical. The porcelain around the electrodes looked new. Where is the oil going?
RE: Beautiful plugs, no smoke, no leaks...
ORIGINAL: Jaggezz
I have the same problem. I was told maybe the valve guide seals, but not if your plugs look good.
+1..a couple were brittle when i yanked mine off after 180,000 miles.
ORIGINAL: myshifter
those umbrella seals are like plastic at your mileage, does it puff a bit in the morning when the oil has a chance to leak into the cylinder overnight?
ORIGINAL: myshifter
do you have oil marks on the concrete drive way where the car was parked???
ORIGINAL: FiveLiterRiceEater
normal.
i went through about a quart a week until my piston ring broke
normal.
