wheel and tire help
wheel and tire help
Ok so i finaly found some wheels i want, but they dont come with tires... i have a 1990 GT and i'm not sure what tires will fit on my car so there will be no rubbing problems... here's the link to the tires they are 17x9 thanks...
http://www.stage3motorsports.com/product/S3M4CR179
RE: wheel and tire help
17x9 might give you a bit of a rub up front if the backspacing is incorrect... dont go wider then a 255 up front or you will have clearance issues
Are you running aftermarket upper and lower rear control arms??? if not, you might wanna get some so you can eliminate the quad shocks.. set a 275/40/17 on those rears and something like a 245/45/17 on the front
I believe you can squeeze a 275/40/17 no problem in the rear and a 255/45/17 in the front. It MIGHT rub a little in the front when the wheel is all the way cranked to the lock. It should only rub on the inner fender (wheel well), if at all.
-P.
-P.
09-08-2015 11:50 AM
