Custom cam VS. Others...
I was looking to get a custom cam. I've heard from alot it will be alot better. The other cam that i was looking at is the trickflow stage 1. Complete setup would be: GT40P heads, Gt40 intake, 24# injectors, mass air sensor, upgrade fuel pump, 4.10's, advanced timing.
I think thats about it.
Do you think overall a custom cam would be better for me than some other cam ?
RE: Custom cam VS. Others...
ORIGINAL: Ninety5five0
-P.
Hey what is the main difference between the Ford cams?
I got a B303 in mine but don't know what to compare it against or what the main issues are between all of them...
B/E/Z/ What the heck?
Thanks,
Ivan
Sorry to hijack the thread...
Thanks,
Ivan
Well, the differences are lift and duration. To get the exact specs youd need to get the ford racing catalog. I know that the B303 is around .490 lift and 280degrees of duration. The E303 has way more lift and slightly longer duration. Im not sure about the F or Z cam. My next build is going to have a custom grind in it, but itll spin REALLY high.
-P.
-P.
The alphabet cams are good for off the shelf cams. They are, however, a one-size-fits-all type of solution. If you don't ever plan on changing anything, you can go with a custom cam and probably get better drivability and idle quality. If you're planning on a blower in the future and want a cam now but don't want to take it apart again, I'd recommend an E. If you're ok with taking it apart and want the right cam for your combination, I'd get a custom cam. Ed Curtis (FlowTech Induction) is pretty good. I had a custom cam from him in an S-trim (14# Pulley) car that made 490 to the rear wheels with a set of AFR's and a Cobra intake. The cam idled nearly like a stocker and was way better at low RPM parking lot type of duty (no bucking) than an E Cam.
Just my .02
Edit: I forgot to mention Cam Motion but they do a bunch of stuff for the turbo set.
- Jeff
Just my .02
- Jeff
In the futur i would like to spray or put on a blower. But i'm not too sure on either of those.....
So lets say i do spray....An E cam or B cam would be a good choice for me ? And would still be a good choice for my N/A app. for now ?
I'm just in a really big hurry to get this motor back together so i can have a car. So right now i'm thinkin an off the shelf cam is gonna be better for me because i'm not too sure what i'm doing in the future, and i want to get it together really quick.
Thanks for all the inputs
I think that he needs to look at the duration @.050
The bigger duration @ .050 will be the more aggressive cam.
IMHO, I'll always take more lift over more duration because thats where torque comes from.
It is possible to use a 1.7 rocker however to play with the lift side a little.....
