spark+gas=no start???
well in my case it does....i've got 35 psi at the rails, i have spark, but its doesn't start?? The spark appears strong, it sounds good and is yellowish in color. is that a common color, or should it be blue? could the timming have jumped? it was fine when i parked it....
RE: spark+gas=no start???
have you checked to make sure the rotor is moving? after that i would check codes http://fordfuelinjection.com/?p=13 or method two shown here http://www.corral.net/tech/maintenance/eecivtest.html
Timing is off.
A car needs three things to run
1.)Air
2.)Fuel
3.)Spark
Is you have all three, you should be good to go. With timing out of range, then the spark and/or fuel isn't coming in when and where it's needed.
Are you having postdetonation/predetonation issues? I mean, does it try to start at all?
-Ivan
1.)Air
2.)Fuel
3.)Spark
-Ivan
dalefrancis88
09-11-2015 07:15 AM
