Will I gain power with this and is it worth it.
I have 1994 GT Headers,H-Pipe,Cold Air Induction. Will I gain More and how much more do you think I will gain by changing Throttle body and Mass air sensor. And I see you have a choice witch one would I need for my mods. I was thinking of BBK Throttle Body
and on the Mass air sensor you go by injector size what size are the stock ones. Thank You
RE: Will I gain power with this and is it worth it.
stock ones are 19psi as far as I know. I don't know from first hand but I'd say you'd get a decent increase from those things. I'd also get a cat-back exhuast setup to complete your exhuast. What brand is up to you depending on what you like best.
All these might cost around 600-700. I would get a good exhaust first and then a MAf. injectors will be good if you spray or you put a blower. In that case you will need a bigger flow fuel pump as well.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
cardsrus1
19
09-15-2015 08:37 AM
kawiguy827
09-01-2015 07:09 PM
