is like the higher the comp. the higher ur RPM goes??
hows does that work excatly
The desired compression varies with your combination. For example, with most forced induction (barring any ridiculous setups like top fuel, etc ) you'll want a lower compression. NA can use higher compression with improved results. It really depends on your combination.
