AFR 185 deal
AFR 185 deal
I have a buddy selling a set of 185's fairly cheap. I wanted to build a mild carb'ed 306 with a trickflow stage 1 cam, and a set of AFR 165's.
My question is, will the 185's be too much for what im going to do with the car? What cam would be the best match for those heads? and should i just keep looking for the 165's?
RE: AFR 185 deal
Are AFR's really worth the money? Do they outperform Trick Flow? I've heard alot about these heads, but I don't know much about them.
I'm debating on whether I should go all Trick Flow (H/C/I) or run AFR heads with maybe a crane cam or something. Which do you think would provide better results?
RE: AFR 185 deal
ORIGINAL: Jaggezz
trickflow rates their top end kit at 350 crank hp
muscle mustangs and fast fords magazine (i think) built a stock bottom end motor with afr 165's and made 400 crank hp
RE: AFR 185 deal
ORIGINAL: AdderMk2
yes they do outperform them
ORIGINAL: Jaggezz
RE: AFR 185 deal
Goto www.trickflow.com and read the technical specs, it shows what they did to get the 350hp. (10 degrees timing, 9.5:1 compression 1.6 RR's, etc.) Who knows what all went into that AFR motor...
RE: AFR 185 deal
ORIGINAL: Jaggezz
What else did it have besides the heads?
ORIGINAL: AdderMk2
ORIGINAL: Jaggezz
http://carcraft.com/techarticles/116_0307_ford/
RE: AFR 185 deal
Seems kinda funny to me that they can add 50hp with just a carb and intake on it. Not to mention the fact that they make the powerband 2k rpm longer. Whatever tho, I'm not convinced that they are really that much better than everything else, with smaller valves even...
