cobra vs gt!
RE: cobra vs gt!
they had 2 95 cobras, a regular cobra and then they had the cobra r which had the 351(5.8) the regular cobra vs a gt has a bigger tb, diff intake, not sure about the cam, diff heads, some minor diff in bodys, valve train is slightly diff i believe. and not sure other then that.
RE: cobra vs gt!
here's what you really want to know. the 95 cobra had about 20-25 more hp. a 93 cobra had about 20hp more than the 95. the difference? intake runner length. it was shortened in 1994 to fit under the hood of the sn95. if you are looking at buying one or the other, get the gt. you can make the gt look and perform like a cobra, and get cheaper insurance.
RE: cobra vs gt!
**** that buy the cobra not the GT. Why be a poser when you can have the real thing?
ORIGINAL: knucklefux
RE: cobra vs gt!
The cobra had a bigger MAF and TB GT40 heads and lower intake and a Cobra upper intake. Slightly different Cam. 13inch disk in the front and 10 inch disks out back. and I beleive 1.6 roller rockers. Also a transmission cooler. Along with all the misc badges and different rims.
ORIGINAL: gtstang86
what are the differences between my '95 gt and a cobra of the same year. i know there are differences in the valvetrain but what are they and is there anything else besides the exterior body parts??
RE: cobra vs gt!
the cobra has 1.7 rockers, here's a list, i think some things are missing:
Engine:
- Configuration 90/degree V-8
- Bore x Stroke 4.00 X 3.00 in.
- Displacement 5.0 L / 302 cu. In.
- Compression ratio 9.0:1
- Horsepower (SAE net) 240 hp @ 4800 RPM (under-rated for insurance reasons)
- Torque 285 lbs./ft. @ 4000 RPM
- Fuel system Sequential Electronic Fuel Injection EEC-IV
- EEC-IV Computer calibrated to Cobra
- Throttle Body Single Bore, Large Diameter- 60mm
- Camshaft Revised, Lobe Lift 0.2822 in. (Intake and Exhaust)
- Intake valves 1 per cylinder, diameter 1.84 in.
- Exhaust valves 1 per cylinder, diameter 1.54 in.
- Pulleys Modified to Slow Drive of Accessories
- Rocker Arms Ford/Crane Roller Rocker Arms
- Flywheel Lightened by 2.7 lbs.
- Pistons Cast Aluminum Alloy
- Cylinder Block Cast Iron
- Cylinder Heads GT-40 Design, Cast Iron with Ford/Crane roller rocker arms and stiffer springs
- Intake Manifold High Flow Cobra intake Plenum Cast Aluminum Upper, Cast Aluminum Lower
- Exhaust Headers Tubular Stainless Steel
- Exhaust System Dual Stainless Steel
- Oil cooler
Drivetrain / Transmission:
- Driveshaft Steel with hardened yoke
- Rear axle 8.8 in. limited-slip differential
- Transmission Borg-Warner T5 5-speed overdrive manual
- Phosphate coated gears
- Bearing upgrade
Gear Ratios
- 1st 3.35
- 2nd 1.99
- 3rd 1.33
- 4th 1.00
- 5th 0.68
- Reverse 3.15
- Final drive 3.08
Suspension:
- Front Modified MacPherson strut type, 400 lbs./in. linear rate coil springs, 25mm anti-roll bar
- Rear Rigid axle four bar links, 160 lbs./in. linear rate coil springs, 27mm anti-roll bar, vertical shock absorbers and horizontal axle dampeners
Brakes
- Front 13.0 in. (330mm) vented disc PBR twin-piston caliper with embossed "COBRA" lettering
- Rear 11.65 in (296mm) vented disc single piston caliper
- ABS Bosch, three-channel, four sensor system
Wheels / Tires
- Wheels Cast aluminum, five-spoke, 17x8in.
- Tires Goodyear Eagle GS-C P255/45ZR17
Steering
- Type Power, rack and pinion, constant ratio
- Gear ratio 14.7:1
Interior:
- White-faced instrument panel with 160mph speedometer
- Cobra logo floormats
- "COBRA" Embossed leather wrapped steering wheel
Exterior:
- Clear Headlight Lenses
- Cobra badging on front fenders
- Redesigned rear spoiler with embedded LED brake light
- Redesigned front air dam/fascia with round fog lights
- Front black plastic license plate bracket (dealer installed)
- LX style rear bumber with MUSTANG imprint
- SVT badge on left side of trunk lid ('94s did not have this)
Engine:
- Oil cooler
- Bearing upgrade
Gear Ratios
- 1st 3.35
- 2nd 1.99
- 3rd 1.33
- 4th 1.00
- 5th 0.68
- Reverse 3.15
- Final drive 3.08
Suspension:
Brakes
Wheels / Tires
Steering
- Gear ratio 14.7:1
Interior:
Exterior:
