Airbag Replacement
Airbag Replacement
If my airbag was accidentally deployed, how hard is it to replace it and do I have to replace anything else (like a sensor/switch) aside from the actual airbag??
I bought my car like this and just found out that the airbag is missing.
It has some kind of cover setup on it.
Thanks,
Ivan
Thanks,
Ivan
RE: Airbag Replacement
Not sure but in my brothers focus he had to replace all kinds of crap. Both bags, clock spring, seatbelt, sensor, and something else. Cant remember what.
All I can say to do is put one in and see if you still get an airbag light. If you do start replacing other stuff. Be sure to have the battery unpluged when you hook the new one up (or you'll have a nice "rug burn"!).
Ebay has the bags all day long for $40....
http://cgi.ebay.com/ebaymotors/94-95...spagenameZWDVW
...and the sensors for around $79...
I would think that everything else wouldn't be too bad. I mean, if we can all do engines, heads, cam, and intakes, what's the problem with installing an airbag and it's componenets if don't by the book?
If some slacker working at Ford making $18/hour can do it, so can we right?
-Ivan
-Ivan
Get ahold of AMP performance in Tempe, AZ they got it all......
Google them of they do advertise in 'Mustangs and Fast Ford' magizine all the time. I get some stuff from them. They are good folks.......
i got an air bag from amp(off of ebay) too them abotua month to finally get it to me! ionly paid 5.00 dollars so it was worth the wait! i didnt plug mine back in.it could go off if u just plug it back in! the system needs to be checked before u replace it!
Thanks for the insight. At first I thought that I had an issue similar to that...accidentally initiated, but later found damage that showed like they could be correlated.
What do "they" check for do you know?
Thanks,
Ivan
Thanks,
Ivan
