Quetion for tech heads out there
I am getting ready to pull my clutch and replace it. My question is on my 94, do I have to drop the oil pan to get to my rear main seal? I figure that I am going to be that close and I have 130K that maybe I should go a head and change out the rear main too. I have my manual but it just describes that I can access it when I remove the flywheel. I am also wondering if I should replace the oil pan gasket with that many miles. It leaking a little oil, so I was going to take care of the rear main, and valve cover gaskets at the same time. The oil pan dosent seem to be leaking but, is it better safe than sorry? Thanks for any help!
RE: Quetion for tech heads out there
ORIGINAL: 94RoadRacerGT
any leak you see is probably from the rear main...leaking on other stuff and appearing as another leak.
no, no need to pop the pan, and no i wouldn't do it.
resurface your flywheel when you do the clutch, and do an adj. cable too.
Thanks. As far as contradictiong I didn't meant to. I was just wondering if with 130K if I should replace it just to be safe thats all. Thanks for the heads up though!
