Horrible Noise - MustangForums.com
Horrible Noise
Old 06-11-2006, 12:51 AM
Bagitupbaby
Default Horrible Noise
i got a 91 LX 5.0, i just took off the four cats on the h pipe, but now there is this horrible clicking noise wen i drive its coming from the back of the manifold, wat can taht be?
Bagitupbaby is offline
Old 06-11-2006, 12:53 AM
boss429
Default RE: Horrible Noise
have you made sure the bolts are all tight?
boss429 is offline
Twisted
ORIGINAL: Bagitupbaby
An exhaust leak? By the way, what did you put in place of the cats you removed?
Twisted is offline
Old 06-11-2006, 12:54 AM
Bagitupbaby
i got them cut off and welded pipes instead
Old 06-11-2006, 12:56 AM
Twisted
Hardcore. If it wasn't doing it before, I would guess there's a leak somewhere. I've heard that exhaust leaks can make tapping/clicking sounds.
Twisted is offline
Old 06-11-2006, 12:59 AM
Bagitupbaby
how can i check for some leaks?
Old 06-11-2006, 01:05 AM
Twisted
I don't know the proper way, but I've done it by inserting a tube into my ear, and putting the other end near the suspected leaky area, and just listening around for the leak. I've also found exhaust leaks just using my hands to feel for moving air, in the suspected area. Hopefully someone will chime in with a better method for you, and to verify that it could be a leak causing the sound. Good luck.
Twisted is offline
Old 06-11-2006, 01:15 AM
Bagitupbaby
how bout if i spray carb cleaner on it would it do anythin?
Old 06-11-2006, 01:19 AM
Twisted
I don't think so. But I wouldn't spray carb cleaner on the h-pipe area of a running car. Just my opinion.
Twisted is offline
Old 06-11-2006, 01:52 AM
lookinforastang
I ♥ Acer
could just be the clamps moving around
when the cars cold get under there and start wiggling parts
also feel around for cracks in the exhaust with hands. only feather it tho cause if u do find a crack and it gets under ur skin its going to be worse than a paper cut
lookinforastang is offline
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
69Volunteer
09-30-2015 10:39 AM
GLOCKer
09-28-2015 07:36 AM
Featured Sponsors
