fuel psi level.....
Old 06-11-2006, 01:21 PM
94ford5liter
94ford5liter's Avatar
Default fuel psi level.....
I just installed a bbk 255lph fuel pump in my car, and I figured with over twice the pump rate of the stock pump i would need a lot less fuel pressure. I have it at 31 psi right now, and I ran the scanner on my car and it says the car is running lean. What do you guys suggest I should try setting my fuel pressure at? Oh I am also running 12 degrees timing.
94ford5liter is offline
Old 06-11-2006, 01:39 PM
94ford5liter
Default RE: fuel psi level.....
anyone have an estimate? my mods are in my sig
Old 06-11-2006, 01:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Bump it a little at a time. Factory is like 39psi. Even w/ the bigger pump, your ecm still tells the injectors how much fuel to provide. So the stock setting should be fine.
PRO50SC is offline
Old 06-11-2006, 03:12 PM
AdderMk2
Banned
AdderMk2's Avatar
just because your flowing more fuel to the rails.. doesnt mean your gonna get more into the engine... our cars run a return system on the fuel rail, which means that no matter how big your pump is... your FPR will only allow 39 psi to remain... the rest will go back to the tank
so your fuel pressure should be at 39psi like pro said... not 31 (your probably viewing your fuel pressure with the vac line still attached
AdderMk2 is offline
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
Sixx
10-05-2015 07:36 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: fuel psi level.....
