suspenstion setup ?
Old 06-11-2006, 06:19 PM
slow 5 oh!
slow 5 oh!'s Avatar
Default suspenstion setup ?
i got a 90 gt im going 2 be using the drag launch springs with the air bags and 50/50 rear shocks now which struts should i get 4 the front 70/30 or 90/10????????
slow 5 oh! is offline
Old 06-11-2006, 06:20 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: suspenstion setup ?
street: 70/30
strip only: 90/10
90/10s are VERY harsh on the street
AdderMk2 is offline
Old 06-11-2006, 07:18 PM
Scout2232
Scout2232's Avatar
What do those numbers mean? 50/50, 70/30, 90/10 etc?
Scout2232 is offline
Old 06-11-2006, 07:25 PM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
ORIGINAL: slow 5 oh!
Auto or stick?
What lowers?
Slicks?
Grimace5.0 is offline
Old 06-11-2006, 08:04 PM
AdderMk2
Banned
AdderMk2's Avatar
its the rate at which the shocks/struts will compress/decompress.
90/10's will decompress alot easier then they will compress. this aids the car in weight transfer to the back tires if they are in the front. you usually want a 50/50 in the back.
50/50 in the front will give a very sporty ride where as a 70/30 will give more of a drag ride while still being streetable
AdderMk2 is offline
Old 06-11-2006, 08:18 PM
luckythirteen13
luckythirteen13's Avatar
get adjustables. even if the car is a track only car 90/10 maybe too loose for your mods and other suspension parts. i like my strange 10 way adjustabl struts because with the turn of a *** i can change my struts
luckythirteen13 is offline
Old 06-11-2006, 08:40 PM
uedlose
uedlose's Avatar
Yea I would also get the strange 10 way adj. struts they are priced right and rock at the track and work great on the street. I am very pleased with ours.
uedlose is offline
Old 06-11-2006, 09:20 PM
tinman
tinman's Avatar
I would need more info on just what you've got for tire type, powertrain mods etc in order to give any info on struts......
tinman is offline
Old 06-11-2006, 09:21 PM
boss429
boss429's Avatar
go 90/10
you'll feel the front of your car lift with every shift
boss429 is offline
Old 06-11-2006, 10:26 PM
Scout2232
Scout2232's Avatar
Those adjustables seem pretty neat, so you just drive down to the track, turn a dial, do a pass, turn a dial and go back home? Have you had any kind of problems with it not adjusting correctly?
Quick Reply: suspenstion setup ?
