Anyone not running a front sway?
Just like the title says, how do you like it? how does it handle around turns? would you recommend it for a DD? thanx for the help! and no I didnt search!
RE: Anyone not running a front sway?
It corners like crap. Lots of body roll. Most shops wont do an alignment with it off either or will tell you it wont be accurate. Other than that there is no difference in handling.
I don't run a front swaybar. I don't have any problems. Of course, I don't try to corner the thing at 100 MPH either....
havent had a front sway bar in a while. easily takes street corners at 25-30mph. ive never had an alignment shop tell me it cant be alligned but i only go to one and they are the best
don't tires wear out prematurely?....i havn't took mine off yet,but had one side break on me...i couldn't steer it at all.
been off for 5 years, no problems here
The sway bar only controls body roll and really has no impact on STATIC alignment, If you have a purpose built vehicle the place you take it to line it up should have no problem with it being removed other than to tell you that it will drive differently on the steet. I have driven with and without them and don't seem to notice any major difference. I work in a shop and most of the time if you go in and tell them why you want it done and why the parts are removed then there is no problem....BUT if the people in the shop want to be stupid, or they are stupid they will through their worthless non-fact based opinion in and prevent you from getting what you want. Well enough from me, run that thing without the bar and see if you like it or not.;) Rick.
I had mine off for about 2 weeks now and it handles about the same as a school bus, and it tends to have bumpsteer while at fast speeds.
but it sure makes it hook better. you will be fine, just dont speed excessively. |
all the people i know r running no sway bar and they turn jsut find...
It corner like sh*t but nothing sub frame connectors wont fix.
