Throttle body question
RE: Throttle body question
Thanks for all the feed back guys I appreciate it. I do have a 76mm mass air sensor with same size tube, thats also why i'm asking to go to bigger T/B cause right now it's too big for the T/B that i have, I have to use rubber spacer sleeve to fit on T/B. It's a manual trans if anyone wanted to know.
Don't worry about changing the TB unless you have an aftermarket intake....60 is fine for the stocker--especially if you will be swapping intakes anyway. It's not worth the extra work since you have to enlarge the opening on the intake.
Luke9222
10-22-2015 11:55 PM
