How much hp will this combo produce?
RE: How much hp will this combo produce?
the way people dispense hp numbers around here, can you all tell me what my big block in my sig makes?
557 inch
A-429 Heads flow 330/210 2.19-1.71
11:1
solid roller 676-690 262-272@50
tunnel with twin 650's
557 inch
11:1
ORIGINAL: myshifter
557 inch
11:1
557 inch
11:1
i know i am
See nobody really knows real hp figures
I'll put I to you this way: The ford GT40 crate engine which has 9.0.1 compression, GT40 aluminum heads (1.94 int./ 1.54 exh.) E303 camshaft, GT40 intake, 65mm throttle body, Shorty Headers makes 345 BHP which is about 300 RWHP with a 15% drivetrain loss.
You have basically the same engine combo with 1.5 more points in compression, 1000 more rpm of power over the e cam and the same head configuration. 325 RWHP or more is what you will make considering the tune is right.
come on the set up isn't "matched" a big cam matched to poor flowing heads?..that compression can be sky high,and still won't do any good...where's the cylinder quench???..
every set up is going to be different...and to myshifter i was going to say 800hp....iv'e been around so many motor combo's and i have to say i like that one
