how much horsepower?
RE: how much horsepower?
The cheapest way to get 300 hp from a stock 5.0 would to add a nitrous kit. However, if you don't want to go with nitrous, my best guess is to get a good set of aluminum heads, a cam, intake, (e.g. Edelbrock has power packages for the 5.0) throttle body, MAF, and exhaust to round it off.. This will put you @ at least 300 hp.
ORIGINAL: 68silvercoupe
well I'd say a set of 3.73 gears..yes it's not an hp mod but acts like 30-40 hp gain
so add the gear
pullies
bigger maf
2.5 exhaust
chip
you as fast as a
300hp car and isn't thats what it's all about?
so add the gear
pullies
bigger maf
2.5 exhaust
chip
you as fast as a
Holley system max has a real good deal for about 2200 dollars and it gives you 350 hp and TFS also has one that gives you 360 and its 2,000 dollars . This is the way i should of went from the start its a no brainer combo and they all match . Should give you 300 to the RWHP . 150 shot nitro kit gets you in the mid 11s maybe even more if you do suspension upgrades .Good luck
im with vfast. the bigger MAf and stock TB well speed up the air flow into the engine air speed on a stock engine is as important as volume and a stock TB is a nough volume, to get you to run with all the guys that have thoose packages, of course you have to do the complete list. THIS IS ONE OF THE CHEAPEST, EASILY UP GRADED DRAG SETUP.
01-06-2016 07:03 PM
09-18-2015 12:25 PM
Other Professional Racing
09-10-2015 11:41 AM
