what should i go for first?programmer? injectors?
RE: what should i go for first?
what size fuel line are you using and what regulator? If you retard the timing a couple of degrees that should help with the mix, I still dont' think larger injectors would help. How much HP are you pushing?
http://www.rceng.com/technical.htm
85% duty cycle is pushing it like I said but unless you're planning on pushing more HP anytime soon, I still think youcan doe something somewhere else to help the A/F ratio.
stock fuel lines...aeromotive regulator
ORIGINAL: Derf00
