upper and lower Intakes ?
I have a 90 mustang Gt, with CIA and basic tune up that i did. i dont plan on heavily modifying the car. I want to buy a cobra upper and lower intake for the looks and performance. If my car is stock will it just bolt right on or not? will i have to change the heads? if so how much horse power will i get from cobra intake?
RE: upper and lower Intakes ?
ORIGINAL: Obsol3te
well ill just say what people are most likely going to say.
Which is, 'Don't go with the cobra intake, get the Trick Flow Track Heat. It's much better for about the same cost.'
yeah I read an article about the proffessional products on www.fordmuscle.com it is the same exact intake as the edelbrock performer rpm, just the european verison of it and you can get it already polished if your looking for that...
ok if i go with a Trick flow or edlebrock will in need to change the heads and lower intake? or will the intake just bolt right on? And how much horsepower will i gain? what other parts will i need,bigger throttle body or maf?
the edelbrock and trick flow come with a the lower intake. you could just buy the top intake but I don't think you would be able to notice a gain. And THEY should line up right...but call both places just to make sure!
