backfire...backpressure?
so i just installed 2.5 flowmaster american thinder on my car with a catless H pipe, and now it backfires in upper RPM, and has no pull in upper RPM either. It is a stock motor with a lumpy cam and GT40 upper/lower intake. Tommorw I am gonna put the stock H pipe back on, can anyone tell me if this is the best idea? thanks
RE: backfire...backpressure?
changing the H-pipe should not have caused this. try resetting the computer by removing the negative battery cable for a few minutes and then reconnect it and drive the car and see if it still does it.
Re-set computer.....then be a man and get an X pipe.
Anyone saying it'll make your car sound like an import is *jacko voice from southpark* just ignorant *jack voice off*. I'd actually pay to find someone be able to take a modern day "big displacement" V8 sound like a nasty *** 4 banger.
Make sure there are no exhaust leaks...sounds like I have a similar setup to you, and after installing an h-pipe w/no cats I had a small leak between my header and h-pipe, and the thing would back fire every time i let off at higher rpm's. Fixed the leak and it was gone.
