600+
will it be possible to run reliable with 600+ hp on a 351 block????
RE: 600+
yes
RE: 600+
Very
RE: 600+
OHHHHHHHH YEA!:D
RE: 600+
^^^ what they said!!! :D
RE: 600+
I hope I can answer that qustion for you this winter :D
RE: 600+
oh yea the guy thats building my motor has a 1000+ hp 351w on spray if that helps u any.
753 lift cam 1150 dominator and some crazy intake and heads |
RE: 600+
How do choose a 351 block, is a 351 a 351 block, or is there a blocks that is stronger and more reliable than others??
RE: 600+
the stock 351w block is good for 700-800hp i believe. you can get a 351 block from dart or other companies that will hold probably 1500-2000hp so it depends on your goals
RE: 600+
A 351W block is basically a 351W block except for pre 74. They are alot stronger than the stock.
