Should i be using fuel rails And what fuel Pump
Alum. Edelbrock RPM Heads
E-303 Cam
Harland Roller Rockers
Edelbrock Performer Intake
Edelbrock 70mm throttle body
Vortech S-Trim Supercharger ( 8 lbs. boost)
BBK Fuel Pressure regulator
24 lb. injectors
Msd retard /timing boost
underdrive Pulley
Pillar Gauges
Cobra Hood
03 Cobra 17x9, 17x10.5 w/315/35/zr17
Mac Shortie Headers,
H-pipe w/cats, Flowmaster exhaust
white face gauges
I dont want to run lean, And does anyone know what Fule Pressure i should be having at idle and then under Boost?
Thanks guys
It's a 94 Gt with 5.0 Stock Bottom end
[IMG]local://upfiles/6214/Zw695133954.jpg[/IMG]
E-303 Cam
24 lb. injectors
underdrive Pulley
Pillar Gauges
Cobra Hood
white face gauges
Thanks guys
RE: Should i be using fuel rails And what fuel Pump
stock is 35-40 psi but I would run at least 40 with a blower to make sure I get enough fuel to not run too lean. best thing to do is go somewhere that has an air/fuel ratio meter and see where it is now and then use the meter to tune the fuel pressure to get it right under boost.
mrappe
09-26-2015 10:16 AM
