haha, nope we switched the fans as well. its a slim v8 fan...so I just ground it off somewhere and take the other wire to the ignition with a fuse attached?
Ok...so I need a fan controller, and a fuse.
I need to ground the fan, then run the positive into the ignition switch and split that wire with a fan controller?
originally i bought an aftermarket fan with a relay which worked really good, for awhile, then the relay took a crap. So i cut the wires and grounded the one and just ran the same gauge through the firewall and attached a connector and ran it through the radio fuse. It works fine and always keeps the engine cool beause its always on. Make sure the fan blows towards the engine or u may have to switch the two wires around to get it moving the correct way.
