How would this work as a 351 base?
Found this deal on ebay, seems to be good.
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
What do you all think of using that motor to build up a 351 or 347? It would undergo a complete rebuild, obviously. THanks!
RE: How would this work as a 351 base?
A 351 can be made by stroking and boring a 302? I don't have the money to buy a completely rebuilt motor - I figure this would be a good base. I need street driveability so I really don't want to go above a 351 .
ORIGINAL: VigCS
Oh. I thought the 302 and 351 had the same block...guess not, or does it?
I'll look into the 351's randy
What can a 302 be made into by stroking? 347? What if you bore (.030" over) and stroke a 302?
Thanks!
Thanks!
ORIGINAL: VigCS
Thanks!
Thanks!
302 and 351W are different blocks, they are similar and will bolt up in the same place
but are not the same.
351 has higher deck height, stronger block and stronger crank
351 uses different distributor, flywheel, balancer and headers.
and you want a 94-98 351W block that is a "roller cam" block.
351 is mo-better and cheaper to build even with the swap over parts you have to buy.
http://www.mustang50magazine.com/techarticles/18818/
ORIGINAL: VigCS
Okay, well I think I'd rather just stroke a 302. What would that punch it out to? 347?
