Better to mod or buy a modded car?
RE: Better to mod or buy a modded car?
when you mod your own car it is the greatest sense of accomplishment you can have. I have put countless amounts of money, time, and sweat in the stang I own. The first busted nuckle becomes a distant memory, but you know everything about "your" car. The first time you fire it up, you have a whole new respect for your car. Have your own project, not someone else's.
ORIGINAL: monsterbishi
I have a personal rule to never buy someone elses modified car, 99% of the time the reasons why they sold it involve repairing and replacing parts or panels.
I understand what some of you mean about the pride and knowledge that comes from modding your own car. I would love do some work to mine, and have it feel like a whole new car--and a racecar at that. I just can't imagine where the money is gonna come from. I guess I'll weigh my options when I have the money to afford either. Thanks for helping me think this through.
ORIGINAL: Twisted
I just had an epiphony. If I can't afford to make my car faster, what are some good modifications to make it slower?
remove the tires
take a dump in the gas tank
remove the windshield
fill it with rocks
take out multiple spark plugs
take an automatic weapon and/or sledgehammer to the block
put an apple in the intake
retard the timing
swap for a 4 cylinder
drive with the oil drain plug off
drive with the brake pedal depressed (spell?)
drive with the ac on
fill the car with playdough
put a brick under your gas pedal
crank the engine until the starter fries, buy a new starter and install, repeat multiple times, then drive
Anyway...when I finally buy a 5.0, I will not buy an already modified car. I won't buy one if it has so much as an aftermarket intake. If it has any mods it means that the people have gone fast in it, and that they've wanted to go faster, and then tryed to go faster. Means they abused it. I'd rather abuse the car myself, then have someone else do it >_<
Buying a modded car isn't bad if you can work on them. I bought mine two years ago for $4000, already with 331 stroker set up, and drove the **** out of it. I saved up a bunch of money, and built a real nice engine for it, and did all the upgrades I wanted when that set up stopped working for me. I spent about $8K for the mods that I have done, and there are still things I will be doing later. I was able to salvage an easy $5000 in great parts that were put in by the last guy between the heads, intake, trans, gears, radiator, etc. I have had nearly every part out of my car since I bought it, and now the car is mine.
