CAR NOT RUNNING RIGHT
i have an 88 gt 5.0 . i have replaced alot of the sensors and such. i was having a code on my computer that something was wrong with the egr vacuum. i have cleaned all the wiring conections and retest the computer and it says everything checks out. so i take the car for a spin and has no or little horsepower till about 4grand then it launchs (pretty hard too) ( need i ad that while it's trying to gain rpm's i don't back out of the gas) what could be wrong. i'm getting ready to test the fuel pressure and make sure it's not the pump. thanks for any help.
RE: CAR NOT RUNNING RIGHT
Check the vacuum line going to your EGR valve. Trace it all the way. Sometimes these lines bend or collapse from the heat. If you haven't toched them they will be covered with black plastic insulation, uncover them and trace them all the way. I had a problem with the same code and that was the problem.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
