tuning question??
tuning question??
any ideas on power and torque? and what would I do to tune this. I am having a hard time finding a tuning program for a 1991 5.0 (besides the JET modules and i heard those were ****)
Heres what i am working with:
Trick Flow Track Heat Intake Manifold
Trick Flow valve covers
Trick Flow 70mm EGR Spacer
AFR 165cc Pedastal mount 60cc combustion chamber Cylinder heads
Proform 1.6 roller rockers
E303 cam
ARP Head studs
Nitto 555R Drag Radials (275/60R15)
Kirban Adjustable Fuel Pressure Regulator
Melling High Volume Oil Pump
ARP Oil Pump Drive Shaft
Electric Fan
MSD 6AL
MSD Blaster Coil
MSD 9mm Wires
BBK 1 5/8 headers
BBK Subframe Connectors
BBK Off-road X pipe
BBK 190 LPH fuel pump
BBK Cold Air Induction
70mm Throttle Body
24lb Injectors
75mm Mass Air Flow Sensor Calibrated for 24lb injectors
Flowmaster 2 chamber mufflers
3.73 Gears
Steeda Upper Control Arms
Granatelli Weight Jacker Lower Control Arms
Steel Bearing Retainer
Steel Clutch Fork
someone had also told me today that my proform rockers were junk......anyone ever used them??
E303 cam
ARP Head studs
Electric Fan
MSD 6AL
MSD Blaster Coil
MSD 9mm Wires
BBK 1 5/8 headers
BBK Off-road X pipe
70mm Throttle Body
24lb Injectors
3.73 Gears
Steel Clutch Fork
09-08-2015 06:25 PM
09-01-2015 08:16 PM
