Injector Install
RE: Injector Install
its pretty self explanitory once you get in there. Just push it up into the rails nice and easy, then when you have em all in there just push them into the manifold. Then you can put the screws that hold the rails in. Its really easy.
There a little more to it, when pressing the injectors into either the head or pressing the fuel rail onto the injectors make sure you lube the o-rings with some silicone lubricant to prevent tearing the o-ring , it has to be silicone lube because the other lubricants destroy the rubber.
-P.
-P.
