Car doesnt start for sh^t?
Have a 89 Lx 5.0 and is hasnt been starting good at all lately. It cranks over for a while then i let off...then when i crank it the second time it fires right up? Timing is set at 14 degrees, new o2 sensors and MAF, fuel pressure checks out ok. Anyone had this problem? Thanks
RE: Car doesnt start for sh^t?
ORIGINAL: scottistang
Havent checked the spark but woudl that be it if it does run fine just takes a while to start?thanks
how much fuel pressure do you have with the key on and engine off, right after you turn the key on? most hard starts are because of lack of fuel, which would most likely be your regulator, but could also be a pump. and like scott said, spark plugs are possible too. but i would check fuel first.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
