Oil change......
#21
RE: Oil change......
ORIGINAL: ikeybmg
theres 2 on yours too bro!
ORIGINAL: Black95MustangGT
wait wait wait..not trying to hijack your thread but..there are 2 plugs i have to losen to change my oil?!? I have a 95 Mustang Gt and i always only do 1 when i change my oil![]
#23
ORIGINAL: cepowers18
Excuse me?? Where is the 2nd one?? I have a 94 GT and I've always drained one as well.
ORIGINAL: ikeybmg
Hehehehehehe!!!
-Ivan
#24
I use the WIX filters out there, best filters you can get!!!! maybe a couple more bux, but from what I've read they're definentally worth it. And I use the Valvoline high mileage oil 10w30 (has some additives that help preserve seals and such).
#26
Stay away from all of the flim flam Fram filters.
One of the problems is a bad/weak backflow valve, so that oil will not drain out of the top of the block when you shut off the motor.
Every time I have pulled a Fram filter from my car it has been dry.
That has not happened since switching to K&N and Mobil filters.
I also see slightly higher oil pressure with the K&N and Mobil filters, ~5psi.
I have several good oil websites listed on my site (bottom of page).
http://www.freewebs.com/vristang/referencedwebsites.htm
One site has a very in depth comparison of many oil filters.
The sooner you quite taking the car to "professional" "technicians" the happier you will be with the quality of work being done on your car.
But that is just my opinion
jason
jason
#28
ORIGINAL: silver91gt
one is on the front hump on the pan, and the other is on the bottom of the pan.
