Low Fuel Pressure??
Low Fuel Pressure??
Hi.. car has been shutting off intermittently lately, so I put a fuel pressure gauge on the fuel rail and I'm only reading 26psi at idle and 32 psi w/ regulator hose pulled off.. what should the fuel psi be at an idle?? Replaced regulator w/ aftermarket non adjustable, do I need a fuel pump? And what kind of pump should I buy??
RE: Low Fuel Pressure??
It runs really good!! I mean for a stock 302..? I don't feel the pump cutting out or anything under a load either.. You should read my other post... cuz I checked the psi BEFORE I fixed the stalling problem, and maybe that had something to do w/ the pressure??
How about mine....not to hijack....mine will studder under a load like a *****(can't drive it), but will idle and rev in nuetral fine..havent check fuel psi yet..sound like the pump?
