hey guys I have a 5.0 block with a 347 stroker kit edobrock performer heads and edobrock performer intake with 190 iph pump and a bbk fuel pressure regulator. i need advice on what injectors to run with the motor 19 lbs or 24 lbs?
the thirty #ers are prally the best for your set up and be sure to calibrate you MAF. you can put more fuel into your motor than what it needs then it will run rich= to much FUEL.
