Whats the best way to use Sea Foam?
RE: Whats the best way to use Sea Foam?
each method does different things. in the gas tank cleans fuel system (lines,injectors etc.), and removes moisture.
in the oil removes moisture. through a vacuum line into the intake manifold cleans carbon deposits off of the top of the pistons.
i've used it in the gas and through the vacuum line, the latter made a noticable difference. if you use it in the oil, don't use very much
ORIGINAL: TENGRAM
ORIGINAL: capnacee
Did you use 1/3 of a can like it said? Less-or-more?
How often do you use it Ten-Gram? And, Did you notice a difference after you cleaned some carbon of the top-end?? Also the guy at the O'Reilly store said the longer you let it sit the better, Just LOOK OUT for the SMOKE...
I have used it in my Intrepid but never in a Mustang. What vacuum line did you guys use? Also, I would rather follow the directions on the back of the can than listen to the guy at O'Rielly's. The guy might be right but until you are positive I would just go off the directions.
yourmom6990
09-14-2015 10:52 PM
