How much horsepower?
Hey guys I was wondering if anyone could give me an estimate of how much horsepower/torque and waht kind of 1/4 mile times i would run on an 88 interceptor with these upgrades.
1. BBK 75MM THROTTLE BODY
2. BBK 75MM EGR PLATE
3. BBK Shorty Headers
4. BBK Off road H-pipe with no cats
5. BBK FUEL PUMP 255 LITERS/HOUR
6. Ford racing 30 lb injectors
7. BBK SSI Intake (honed out)
8. Ford Racing Aluminum Driveshaft
9. A/C eliminator
10. Smog pump eliminator
11. Ford Racing 3.90 gears
12. MSD 6Al Ignition Kit
13. MSD Blaster 2 Coil
14. MSD 8.5 MM wires
15. NGK spark plugs
16. MSD Distributor
17. King Cobra clutch
18. Rebuilt t-5 tranny world class
19. Pro 5.0 shifter
20. Steeda clutch cable
21. Hypereutectic Flat Top .30 pistons
22. lunati camshaft with Duration 284/292, Lift .500/.510
23. Hi flo oil pump
Block is bored .30 over and has stock crank
Heads are also ported, buit stock
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
RE: How much horsepower?
If your doing cam and intake work, you should really consider grabbing a set of heads. When you get all done it will be the weakest point in your set-up, and your going to need some of the same gaskets again to up-grade them at that point.
If that set-up doesn't yield 13's, work on the shifting
