want to drop
#23
RE: want to drop
Look at the H&R sport springs and put in a set of poly spring isolators. That should keep your ride height where you want it. You should replace your stock shocks/struts when doing springs b/c your stockers are designed to dampen stiffer/lower springs....
#24
RE: want to drop
ORIGINAL: nacanitihs
nice do they make just 1" lowering springs or are the lowest 1.5"? cuz i have 9" wide rims and they rub a little when the wheel is totally turned. and do you think they would rub any more w/ the 1-1.5" lowering springs? and would i need to get new controll arms or could i stay w/ the stock seeing as its not a 2" drop?
Matt's 95 Stang
10-05-2015 07:16 AM
zanemoseley
09-06-2015 12:58 PM
