How fast are you??
Old 06-24-2006, 04:58 PM
5.0stanger
5.0stanger's Avatar
Default How fast are you??
I was just reading other post on how people were running in the 1/4 or how they will run. How about a list of mods, et, mph and 60' times to help people compare times and figure what they will run....I will start it off
I have ported stock heads decked .030 with 1.7 rollers.
Equal length shorty headers/ Offroad H/ Flowmaster catback
Under drives
Ram air/ K&N
electric fan
smog pump removed
3.73 gears with rebuilt posi
T-5 fresh rebuild and newer clutch
Steeda triaxe short thow with hurst stick
aluminum drive shaft
Ford racing Wires
MSD blaster coil
14* timming
New goodyear 40/255/17 tires
I think that is all...
60' 2.126
et 13.732
mph 104.28
Give us what you got!!!
5.0stanger is offline
Old 06-24-2006, 05:05 PM
ben5.0
ben5.0's Avatar
Default RE: How fast are you??
im too slow to post
ben5.0 is offline
Old 06-24-2006, 05:08 PM
fordracing1122
fordracing1122's Avatar
^ no ones to slow...
I have 1 5/8 headers, Tun able Induction CAI, o/r x pipe, flowmaster cat-back,
timing set to 15 degrees, an adjustable fuel regulator...
60'- 2.3
1/8-9.59
1/4-14.774
mph- 94.9
fordracing1122 is offline
Old 06-24-2006, 05:14 PM
302RideOrDie
302RideOrDie's Avatar
uh... I got my sig and ran with a 96 cobra, he got me by a fender, I havent went to the tracks yet, so I dunno what I run..
302RideOrDie is offline
5.0stanger
5.0stanger's Avatar
No one is too slow..post away..this isn't a contest, just to help people find out what they can run and with what mods will make them go faster. Maybe someone has a stocker and is wondering what they will run...POST EM UP[sm=icon_rock.gif] Tell us how fast, or slow you are!!
Old 06-24-2006, 05:43 PM
95hooptey
95hooptey's Avatar
95 Gt vert
aod
under drives
76MM maf
Mac long tubes
H-pipe
15.8 @ 93
After a 6 pak........................14.2 @ 98
95hooptey is offline
Old 06-24-2006, 05:52 PM
FullAuto
FullAuto's Avatar
Combo - 3.25" stroke, Twisted Wedge heads, Performer RPM intake, 1.6rr, mild hyd. roller (.544/.576 224/230 114), LT headers, o/r H-pipe, Dynomax mufflers, 75mm TB, 80mm MAF, 60lb injectors, Novi 2k @ 13psi, methanol injection. Still has all the power robbers on the front of it (stock clutch fan, a/c, ps), PA Supercomp C4, 3.73s.
Power - Made over 600rwhp with 93 octane, no methanol, stock A9P, through an AOD at 5700rpm and a/f <10:1. Lost a header gasket, through off a/f reading and pull was stopped. Now it's a C4.
Track times - 10.43 @ 131.5, 1.7x 60' on 91 octane and radials. Race weight ~3380. Not using transbrake. It will go 9s on pump gas and radials when the rear suspension is addressed.... which is coming very soon.
People are generally most amazed at the intake supporting those numbers, the fact I still run the stock fan and air conditioning, and that is tucks nicely under the stock hood.
FullAuto is offline
Old 06-24-2006, 06:09 PM
91lxstang
91lxstang's Avatar
sry but im pretty sure youd get smoked by a 305 hp cobra
ORIGINAL: 302RideOrDie
91lxstang is offline
Old 06-24-2006, 06:19 PM
slobra1
slobra1's Avatar
yes thats a 14.0 to high 13 second car stock
slobra1 is offline
Old 06-24-2006, 06:31 PM
hectanooga
hectanooga's Avatar
302 V8 - 8k on motor
E303 Cam
3 Angle Valve Job
Headers (Sorry... don't know which brand)
BBK Straight Pipe... no cats
Subframe Connectors
G Force brace
3.55 Rear
Flowmaster dual chamber mufflers
T-5 Tranny
There might be some other things I am forgetting.
Previous owner's best time was 13.98. I haven't run it yet because there are a few things I would like to upgrade.
hectanooga is offline
Quick Reply: How fast are you??
