RPM's When Shifting A 5spd and How To Double Clutch
RE: RPM's When Shifting A 5spd and How To Double Clutch
ORIGINAL: Tims 88GT
WTF is it with people asking this question, no one can tell u how to drive a stick. you can only get slight imput on how to do it. u never shift exactly the same, because the road is always differant. so if u take off going up a hill are u going to shift to second at 2k? no your not, more like 3500 or higher. If u try to stay under 2k all the time your going to strain the motor and its going to use more fuel, drive the car so the motor pulls easy do not dump into it and do not strain it. double clutching is a joke with a syncronized trans. dont listin to F&F movies
ORIGINAL: Myfetang
The only time I will double clutch and when its useful, is on highway driving. If I'm going say 110km (65) and I'm in 5th gear, and I need to pass someone quickly, then the best thing to do that I have found is clutch it, take it into nuetral rev it to about 4000rpm and quickly put it into third and go. It allows you do drop your gear properly by matching your RPMS to that suited gear without binding anything in the tranny. Its a good way to downshift properly. My 2 cents
Here's a quick little clip of me double clutching. http://media.putfile.com/shift-vid
ORIGINAL: 66 Hardtop 5.0
Why don`t you just rev it the first time you press the clutch? No need to double clutch when downshifting either
ORIGINAL: Myfetang
in everyday driving, i usually rev about 2500 on most shifts which should get u the best gas mileage, around 16-17 around town. but u can rev it as high as u want. i race my car and shift at about 5800 rpm banging gears down the track with 111k on it and it still runs great afterward. these cars have strong motors.
ORIGINAL: Myfetang
ya, I rev it when I push the clutch in to change to 4th.
why would you waste time clutching it twice????
