quick thermostat q
RE: quick thermostat q
and what's a good radiator and water pump?
i was looking at summit racing and they had a bunch of brands for radiators but no 3 row designs? would 3 rows be an overkill?
and is this a good fan?
http://store.summitracing.com/partde...5&autoview=sku
Yea, 160 would be fine..mine still heats up a bit when you get in to it. It had NO thermostat before I put on in and it ran a little warmer...........The thermostat at least gives the radiator a little time to cool the coolant.
The Summit site has a horsepower kit with a thermostat and its liek 165? I got a 160 at O'Reily..........
A 160° t-stat is a to be installed, you may want to check this article. If coolant temp is getting above 220°, even in 100° temps places, you could be masking a cooling system problem that needs to be checked and corrected. My 2¢.
