need some help from the pro's can you do it
i have a couple of question's first of all has anyone done the torque box reinforcement how is it does it work do you like it have you had ANY MORE PROBLEMS is it worth the money or should i weld up the old ones. i was gone to do both upper and lower. do you know if a mustang / capri trans mount up in a 91 lx it says close to t-5 ratio it on ebay just woundering. thank you for your time
RE: need some help from the pro's can you do it
If you want a good house....build a solid foundation.....reinforce them, that's one of the upgrades anybody thinking about doing any strip or whatever racing, should do. My 2ยข.
"YES", If you are planning on having any power, buy the rienforcements. You can also weld up the stock boxes, to make it stronger. Trust me once you crack one, it will never be able to be repaired, only replaced... It happened to a friend's car, it sucks. I bought my rienforcements from UPR, they were around $70. Well worth the money. Fairly easy to install, you need two people one under the car, and one in the car to line up the bolts. The kit gives you a diagram, so if you follow it you really can't mess up... Good luck. Synyster
JoshyGT
09-19-2017 08:52 PM
