Rpm ques....
Rpm ques....
What do u need for rpms to be higher? Mine redlines at 6k but cant u just buy a face that redlines at 6k an really redline at 5k? Basically what is the deal with rpms? How do they work? Thx
RE: Rpm ques....
ORIGINAL: 91LXStang2727
RE: Rpm ques....
Yea i understand all that but im just asking basically how do you know when your engine redlines if lets say u bought an aftermarket face and it says 6500 and u really redline at like 5500? Do you kinda get wut im askin? Its sorta hard to explain.....
RE: Rpm ques....
i see what your saying.... unless you changed the internals/valves and stuff of your engine, your redline will be the exact same as before..... trust the stock gauges, not aftermarket on your true redline....
RE: Rpm ques....
RE: Rpm ques....
Well the thing is is that i just bought the car a couple months ago and it has an aftermarket face that redlines at 6k so how would i know if that is the correct redline? And also when would u change the rpms? thx
p.s. its the tach next to the speedometer, gas,battery an all that good stuff.
RE: Rpm ques....
The redline on the face dosn't mean that your motor actually redlines at 6g. All motors are different. Just get on your car in 2nd gear and see where it stops pulling, and that will be your particular redline... Synyster
RE: Rpm ques....
ORIGINAL: Synyster Racing
RE: Rpm ques....
Well, My stock gauge says that my redline is 6g, But my motor peaks at 6800. Even stock motors are different. My first Stang said 6g, but it only pulled to 5800. If you wan't to shift where Ford tell you to, then go ahead, but if you car stops pulling at 5500, or even 6100, your losing power... Don't have to be a scientist to figure that out... Synyster
RE: Rpm ques....
