Why?
RE: Why?
You get get a trac-loc rebuild kit from FRPP for $40 bucks and than have someone to install it. They will most likely charge you about $200-250 to redo it. So your looking at a total bill of somewhere around $300. If you dont have gears already get them while you are at it.
http://store.summitracing.com/partde...5&autoview=sku
RE: Why?
Ok before you run off and rebuild your trac-lok, go ahead and change the oil in it. Get some synthetic gear oil and MAKE SURE that it has limited slip additive!
When I had my gears put in the first time it was by an "OLD SCHOOL" mechanic and he threw in regular gear oil and it became a one tire fryer. Change the oil and it worked perfect.
7 dollars for oil and 2 dollars for a gasket beats $200+ for a rebuild.
