Help 91 notch
Help 91 notch
Hello new to this forum and need some advice. This is my second stang had a 88 notch before and now bought a 91 notch. The car runs like crap ( of course when i looked at it before I bought it it ran well ) The car can not get out of its own way. I changed the plugs wires cap fuel filter played with the timing. The car also runs rough on a idle when it warms up and dies at lights. The car has underdrive pulleys and I know the the amps usually run low at a idle but they dont kick up while the car is driven. ( my 88 would drop down and shoot right up) I made sure the firing order is correct, there are no leaks. I dont know if the maf is bad how do you test it ? or this motor is just tired and help would be great !!
Also looking for a clean trunk lid and front fenders must be clean !
thanks
Joe
thanks
Joe
RE: Help 91 notch
you check fuel pressure? fuel pump might be going out.
your cats might be clogged also.
sounds like alternator might be going bad if volts dont come back up
under accleration, low voltage would also cause problems.
RE: Help 91 notch
Check Codes to see if the MAF, or any other sensor, is bad. also i would recommend checking all of your grounds (you should also read this About Grounds)
RE: Help 91 notch
The battery died on me last night cause it has a electric fan that runs off a basic on off switch and i forgot to shut it down. I charged the battery for a good time today cause the car would not hold a jump last night. It would die and could not restart. Now after charging the battery the amp gauge went right to the middle until I turned the lights on and fan then the car ran like sh*t. I am wondering if the alternator is junk and the car was running off the battery before. Any ideas would be great
RE: Help 91 notch
check all your plug wires for cracks/burns
test the alt, i am betting it needs replaced
i havea clean trunk...the one in my sig, it has a spoiler on it though, thats why i got a glass deck
SteelerNation82
09-09-2015 09:06 AM
