What injectors?
What injectors?
I have a 93 must and it has a vortech 8-10lbs. I am going to put new injectors and mass air meter on it. Can someone help me with what size I should use for both? I will probably get a TB at the same time. Which one should I use? My car has no other mods on the motor. I will eventually put the GT-40 intake on and the afr heads and probably the e-303 cam. Dont want to have to change the injectors and stuff again if possible. Please help!
Thanks for any help
Thanks for any help
RE: What injectors?
Do yourself a favor and buy them once. 42#ers and the 75 mm pro tube from Pro-M
http://www.jdsperformance.com/index....=item&inmake=0
You won't be sorry!!!
RE: What injectors?
ORIGINAL: PRO50SC
RE: What injectors?
ORIGINAL: PRO50SC
RE: What injectors?
ORIGINAL: angcobra
agree go with the 42#, Is Pro-M still in business?
ORIGINAL: PRO50SC
RE: What injectors?
+2 for the 42s and the Pro M (Professional Mass Air Systems) meter. I'd probably go with an 80mm though. And I'd buy from Dave at JDs Performance also.
Just get a 65mm TB if you plan on upgrading to a GT40 intake. If it were me though, I'd hold off on the TB, choose a different intake to upgrade to, and buy a larger TB to match the other intake.
