smoken cobra
smoken cobra
the car has a vortec v1 never owned a car with a sc is possiable for the sc to force oil in the intake burn it off as white smoke car run good. just smokes bad under load and when u let of highway speed no smoke any help.
RE: smoken cobra
if the supercharger has an internal oil leak, then yes... maybe
take apart your intake tubing and see where abouts the oil enters the intake. this will give you an idea where its coming from.... however.. it sounds more like rings to me
RE: smoken cobra
its coming in from the vacum tube from the vavle cover filler. and that ine runs down ito the the front of the sc so its alomst getaing sucked in i also noticed a few vaccum lines off. thinking of blocking it off and running it to se if it still smokes.
RE: smoken cobra
if you block off that hose you will blow lots of gaskets, it happened to me
burning oil, hmmm, just plug it off and oil everywhere, blew the rear seal, intake and valve cover gaskets.
you could just put a breather cap on the oil fill tube.
or get a water seperator for air compressor lines and add it in-line there.
11-10-2015 11:39 AM
Dan04COBRA
09-30-2015 11:46 AM
