Anybody here running a Trick-Flow topend kit N/A ?
Hello all:
Was looking at those Trick-Flow topend kits I have a 93 GT with an AOD that i recently got. Only mods I have for it so far (but none of it installed) is BBK ceramic headers, H-pipe, and exhaust. I also have new poly motor & trans mounts, and FRPP B springs & KYB GR2s.
I was thinking of going with the trick-flow topend kit after upgrading my TB (and was kinda thinking of getting a BBK SSI w/ TB and selling the trickflow) and MAF. I was wondering what kind of power increase I could expect with a proper tune and upgrading to 24lbs injectors.
Just wondering what you guys were getting... I know someone here is using this setup. Thanks.
-- OJM
-- OJM
RE: Anybody here running a Trick-Flow topend kit N/A ?
the BBK SSI is a great buy if u wanna drop that much on a intake and tb..i would tho..you will see a decent gain from it..they say it out performs a ported cobra intake.. GO FOR IT
I have the TF top end kit and am very happy with it. I've heard mixed reviews on the BBK SSI kit, but the power gains in MMFF a couple months ago was pretty compelling.
I just heard leaks and things like that could be a problem.
I am running the street kit and I also have an AOD. You will definetly need gears and the AOD sucks. I wish I had a manual. Does anyone know if you can change the shift points.
ORIGINAL: 50lxnotch
dont you mean the track heat kit? i saw top end kit and i was like wtf? lol.
the BBK won't give you any different #'s than the Street heat will....why go thru all the trouble of selling it if it came w/ the kit?
I have the TFS top end kit with a 5speed. Typical results is about 100rwhp more over stock. If my car ran 190rwhp I gained 110rwhp.
I am running 24LB/hr injectors also. You will also need to get a larger fuel pump and an adjustable fuel pressure regulator.
ORIGINAL: gspfunk
No, he's talking about the top end kit...H/C/I all in one pkg...
ORIGINAL: 50lxnotch
