Water guage....
RE: Water guage....
Corrosion inside the radiator. You'll know it when you see it. See how the ends of the tubes in the pic are nice and clean. That's how it should look. It will prolly be full of corrosion on the ends if it is old and or hasn't been taken care of.
RE: Water guage....
Another way to check the fan clutch is to take a rolled up newspaper and touch the spinning fan blade from the motor side with the motor running. If the fan blade stops turning, the clutch is completely shot. Note; Don't try this trick with body parts, only a rolled up newspaper, and be careful to stay out of the belt.
jwog666
12-27-2021 08:09 PM
