Front rotors/brake question
06-29-2006, 11:26 PM
RE: Front rotors/brake question
but i dont i made sure its clean all the way around i checked 3 times because i thought new calipars and fluid would do it
06-29-2006, 11:30 PM
you need to bleed the lines, not just put new fluid.
06-29-2006, 11:32 PM
The Rogue Mod
If the rear brakes are not adjusted properly it will cause a low brake pedal.
06-29-2006, 11:42 PM
i did bleed the brakes like i said 3 times to make sure
thanks PRO im doing the rears tomorrow once my boss orders the shoes for me
06-29-2006, 11:43 PM
Quote:
ORIGINAL: PRO50SC
+1
06-29-2006, 11:48 PM
The Rogue Mod
Quote:
ORIGINAL: HACKGT350
Well, as they sit right now, do the drums come off w/o any drag or spin freely on the axle? If so, they are out of adjustment.
06-30-2006, 12:05 AM
the passenger side does. i work in a shop now so if i have any problems my boss will help me out
06-30-2006, 12:57 AM
For the original question. Did you clean the rotors before installing them. They come from the factory with a light glaze of oil to keep them from rusting. If you didnt depending on how many miles you put on teh new brakes they might be shot.
06-30-2006, 01:01 AM
Quote:
ORIGINAL: silver91gt
means you got air in the lines.
or a bad booster
06-30-2006, 01:11 AM
i didnt do new rotors they are about a year old i got loaded calipars and new fluid
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
09-01-2015 08:16 PM
